Where is the VSS located?
2007 CHEVROLET TRAILBLAZER
189,260 MILES • 4.2L • V6 • 4WD • AUTOMATIC
DJ ART
  • 9 POSTS
Can you please tell me where the vehicle speed sensor location is? I've replaced the 2 in the tail shaft of the transmission that thread into the location but apparently there's a 3rd that has a bolted hook connected to it but i cannot seem to find it. Also, i have replaced the 2 front ABS wheel sensors and no change. My vehicle will not shift at proper times and the speedometer will not work at all. I've searched numerous times but cannot find any information on it. Also, i have seen the posts online and all the pictures on here and they only point to the 2 sensors i have already changed.
Mar 18, 2022 at 10:23 AM
Take a look at the two pics I attached. There is an input and output sensor related to the transmission. There is also one in the rear of the transfer case.
I attached the pics below showing them. Let me know which ones were replaced. Also, let me know what diagnostic trouble code was found.
See pics below.
Mar 18, 2022 at 8:51 PM
DJ ART
  • 9 POSTS
Joe, thanks for the response. Okay, so pic #2 are the ones i replaced. I'm actually looking for #36 in the first pic, that's the one i haven't found to replace.
Mar 18, 2022 at 10:33 PM
That specific sensor is model-dependent. You may not have it on your transmission. If you do, it will be on the passenger side in the transmission tail housing. However, because this is a 4wd, chances are it isn't there.
Let me know. Also, do you have the specific codes that were stored?
Mar 19, 2022 at 6:14 PM
DJ ART
  • 9 POSTS
Yes, the code was a p0502 i believe andy obd2 reader said vehicle speed sensor.
Mar 19, 2022 at 10:17 PM
DJ ART
  • 9 POSTS
Joe, thanks for the response. Okay, so, pic #2 are the ones i replaced. I'm actually looking for #36 in the first pic, that's the one i haven't found to replace.
Mar 20, 2022 at 4:27 PM
The two in picture two are on the transfer case tail housing. The one on the outside of the transmission (number 36 pic 1) is likely not there. It is likely for a 2wd vehicle. The only other one is internal, number 250. Is that the one you are referring to?
That is an input speed sensor located at the front pump on the transmission. See pic 1 below. Is that the one you didn't replace? Also, can you tell me what the code was you had that led you to the speed sensor?
See pic below.
Mar 20, 2022 at 8:13 PM
DJ ART
  • 9 POSTS
That is the only one i havent replaced. I was not aware there was an internal speed sensor. The code i received was the p0502 code which led me to the speed sensor.
Mar 21, 2022 at 3:16 AM
DJ ART
  • 9 POSTS
Also, would that internal one cause the speedometer not to work ?
Mar 21, 2022 at 3:19 AM
The input speed sensor works in conjunction with the output speed sensor to determine the speed and proper gear ratio. However, if the input one is bad, you will likely experience odd shifts, hard shifts, or codes specific to gear ratio issues. Other than the P0502, were there any other codes? Do the other gauges on the instrument panel work? Does the speedo do anything?
Also, the internal one shouldn't have an effect on the speedometer. That is the one at the rear of the transfer case that you already replaced.
I attached the diagnostics for a P0502, which is specific to an output speed sensor. Take a look through them and let me know if you are comfortable performing them.
Here is a link that you may find helpful:
Let me know,
See pics below.
Mar 21, 2022 at 6:34 PM
DJ ART
  • 9 POSTS
I will try all these tests, thank you for the amazingly detailed information. Also, can the TCM have any effect on the speedometer or sensors not responding? Reason i ask is because i talked to a shop that said the reprogramming with a new transmission should have been done and if it wasn't, the transmission was just "guessing" at what points to shift at until it stopped guessing. Is this a possibility as well?
Mar 21, 2022 at 9:57 PM
Programming should have been done, but if there was to be an issue, it would have happened right away. The TCM, which certainly plays a role in the issue, either knows something is right or wrong, and it would have indicated an issue. I don't see how it would finally get tired and stop working. Has anyone tried reprogramming?
Let me know what you find with the tests.
Mar 22, 2022 at 5:57 PM
DJ ART
  • 9 POSTS
No, that's my next step in this whole fiasco. The guy i talked to has been in the industry for over 25 years, such as yourself, so i trust the advice I'm given and put it on my troubleshooting list. I haven't tried the testing as of yet since i need to get the time to do it from work and the vehicle is lowered so i need to get it on some ramps. I have everything written down and your illustrations printed to follow and appreciate everything you have provided.
Mar 22, 2022 at 6:23 PM
DJ ART
  • 9 POSTS
Also, pertaining to your previous question. No other codes were given other than the p0502. All of the other gauges work properly other than the ABS lights coming on now.
Mar 22, 2022 at 7:13 PM
Sounds like a plan. The ABS light is the result of the other problem. They all tie together.
Mar 22, 2022 at 7:59 PM
