Speedometer, back up lights and cruise control are not functioning at all
2001 HYUNDAI SANTA FE
106,000 MILES • 2.7L • V6 • 4WD
JENNYJEN1
The fuses are good. I believe its the vehicle speed sensor (VSS) but am not 100 percent sure where it's located. Does anyone know?
Dec 7, 2020 at 5:38 AM
I am attaching the vehicle speed sensor location but just so I understand, these issues all happened at the same time or did you just notice it? I suspect these are separate issues so let's address them one at a time and if we fix all them at the same time then that is just a bonus.
Let's start with the speedometer as that may be the speed sensor.
I attached the location. However, let's start with checking for codes. I am hoping you have a P0501 and we can go from there.
Dec 7, 2020 at 9:11 AM
JENNYJEN1
There is no check engine light on. I was told at AutoZone that they can't read a code with no check engine light? Not sure if that is true. The car is one I just bought and so I am not sure if it happened all at once but I do know that there is one fuse for the reverse lights and the VSS. So I assumed after some research that that is the issue.
Dec 7, 2020 at 7:08 PM
Okay. That is not true. Just because the light is not on, doesn't mean there are no codes.
However, with that info, I would just go to the speed sensor and make sure it is connected and if it is, replace it and go from there.
Dec 8, 2020 at 5:43 PM
JENNYJEN1
I will work on it this weekend. I ordered one so it should be in by Saturday. I will let you know how it all turns out. Thanks, Jen
Dec 8, 2020 at 5:53 PM
Sounds great. We will wait to hear back. Thanks.
Dec 9, 2020 at 7:04 PM
