The VSA and ABS lights are on
2005 HONDA ODYSSEY
209,300 MILES
MARK AL SANGALANG BALACCUA
the VSA and ABS lights are on. while the engine is on the sliding doors are not working. it will be open when i turn off totally my car. hoping that you can help me to fix this problem thanks.
Feb 20, 2017 at 8:32 PM
MHPAUTOS
  • 31,937 POSTS
It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Feb 21, 2017 at 12:46 AM
there a code appears when i plug a diagnostic tester. the code is 15-01 rear right ABS, but we already removed clean and check it. we did not find any short circuit or open circuit. it is good, but still have the VSA and ABS lights on.
Feb 21, 2017 at 7:52 AM
Hey MARK,
You need to replace the sensor which is probably the problem. I don't think the door will work when the engine is running as a safety precaution.
Please let us know happens so it will help others.
Best, Ken
Feb 23, 2017 at 3:20 PM
