2007 Volvo XC90
2007 VOLVO XC90
84,000 MILES • 6 CYL • AWD • AUTOMATIC
HELENAG22
My left blinker wasn't working so I unscrewed it without removing the battery first. Now I connected it again and neither blinker is working, I guess I erased the computer chip..HELP! Is there any way to reset?
Aug 2, 2010 at 9:00 AM
JIS001
  • 3,412 POSTS
No you did not erase anything. So let me see if I understood this right? Did you remove the blinker switch? If you did, then did you install a new turn signal switch? If you did install a new switch, did you remove the clear tape covering the terminals of the switch? What is the turn signals doing now? Does the arrow light come on and not blink anymore? Do the hazard lights work? If you can give me more info I may be able to help?
Aug 3, 2010 at 1:37 AM
