We have a 2006 Volvo XC90, with a 5-cylinder turbo. It started making a high pitched whine when the key is turned on and continues after the car is started. I've located the source to be some knod of small pump directly behind the Driver's side headlight. I could read "PUMPE LP89" ,I believe. It has several connections on it. Some eletrical and I assume some fluid. Can you identify this item for me from my description and tell me the seriousness and expense of the problem. Everything seems to function properly, but the noise is annoying.
Thx
Thx
Aug 31, 2009 at 12:39 PM
