Driver's Side Not Cooling
2006 VOLVO XC90
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
KINGREALTY
When the a/c is on, the driver's side air vents do not blow cold air, but the passenger's side does. Also the backseat vents behind the driver does not blow cold air either, while the one behind the passenger blows cold air. Both air settings are set to the coldest.
Pls Help
Aug 31, 2010 at 1:03 PM
JIS001
  • 3,412 POSTS
You could be low on refrigerant. Have the system checked to see how much refrigerant is in there. If you are low then look at the condensor for leaks and also pay attention to the A/C lines near the firewall for leaking orings. Good luck and let me know what they find.
Sep 3, 2010 at 12:52 AM
GCWILL1
Air Conditioning problem
2006 Volvo XC90 Two Wheel Drive Automatic 80,000 miles
I am troubleshooting the A/C system. When I start the engine and turn on the A/C the air that comes out of the vents is not cool.
The fan blower works properly
The A/C light illuminate when the button is depressed. I have not used the systems since last year. The car has not been in the shop for anything but regular service, brakes and oil change.
What else can I check? Please help.
Jul 18, 2019 at 6:43 PM (Merged)
YASGER
  • 83 POSTS
hard to say... low freon first but if it is below 40*F they some times do not turn on as well...
[quote:3e5fd126d6="gcwill1"]Air Conditioning problem
What else can I check? Please help.[/quote:3e5fd126d6]
JIS001
  • 3,412 POSTS
Does cold air blow out at least from the driver vent? Can you see the A/C compressor clutch engage? Let me know? If you are low on freon try looking at the reciver drier from the bottom. You will see green dye all over if the seals are leaking. If theye are then you can have just the seals replaced with out replacing the drier. Also look at the A/C lines going to the evaporator at the rear firewall of engine and check for oil and dirt build up. If you see that then those seals are leaking as well, If you dont see any leaks and you have rear A/C then the seals in the rear evaporator could be leaking from there.
