Hello -
I have attached the info
Located right side passenger compartment under soundproofing panel.
Service and Repair
Notes
Air cleaner passenger compartment, replacing
Removing the passenger compartment air cleaner (ACL)
Remove:
the soundproofing panel.
the screws for the cover
the cover.
Pull the air cleaner (ACL) downwards/away.
Installing the passenger compartment air cleaner (ACL)
Install the air cleaner (ACL). There are 2 alternative positions for the air cleaner (ACL). See the illustration.
The pollen filter (standard) must be installed in the smaller compartment (1).
The multi filter (cars with an air quality sensor) must be installed in the wider compartment (2).
NOTE: Install either the pollen filter or the multi filter. Both filters must not be together.
Install:
the screws. The front left screw must not be tightened to more than 0.8 Nm
Dec 21, 2008 at 12:26 AM
