2004 Volvo XC90 Transmission Service Urgent warning message
2004 VOLVO XC90
135,000 MILES • 6 CYL • AWD • AUTOMATIC
SHAZLETT
For the past week I smelled a burning smell off and on while driving and a few times had the gears slip while driving. I checked the transmission fluid and it was full and not too dark, looked normal. Yesterday had the above message show up. Any ideas what the problem may be?
Thank you!
Sep 10, 2010 at 10:50 AM
JIS001
  • 3,412 POSTS
If this is the twin turbo inline 6 engine and the transmission code comes up as an incorrect gear ratio, then you will need to replace the transmission with the aux cooler, radiator and transmission lines. If you only replace the transmission fluid will get contaminated and cause premature failure of the new transmission. You would also need to update the transmission module software.
Sep 11, 2010 at 1:09 AM
