The SRI lights the first time the ignition is switched on after the service interval has been reached. The SRI will continue to illuminate, and remain illuminated, for 2 minutes every time the ignition is switched on or until it is reset. The SRI can be programmed for distance traveled, time since last service and engine hours since last service. Programming is done using the Volvo factory scan tool.
Starting from the 2002 model year, the need for service is indicated partly by the lamp and partly by a text message, TIME FOR SERVICE or TIME FOR REGULAR SERVICE. The SRI can be reset using the Volvo factory scan tool (or equivalent aftermarket scan tool), or using the following method.
Turn ignition to position I.
Press and hold in the reset button for the trip odometer.
NOTE:Turn key to position II within 2 seconds.
Turn ignition to position II.
Hold the reset button for the trip meter until the original value has been reset.
NOTE:Starting from 2003 model year, a general yellow lamp will light when the reset button must be released.
NOTE:If the reset button for the trip odometer is not released within 4 seconds, the SRI is not reset.
Release the reset button for the trip odometer within 4 seconds. The instrument cluster will give an audible signal when resetting is completed.
If the trip meter is already reset, the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
2003-06 XC90
Jan 14, 2009 at 8:20 AM
