Hi fezzik414,
Thank you for the donation.
Here are the procedures for replacing the tailgate wiper motor.
MOTOR, TAILGATE WIPER, REPLACING
Removal
"¢ Remove the rear windshield wiper arm. See Tailgate wiper arm/blade, replacing
"¢ Remove the tailgate panel. See Lower tailgate panel .
"¢ Press the mounting for the washer hose towards the motor.
"¢ Remove the washer hose
"¢ Disconnect the connector
"¢ Remove the screws.
"¢ Remove the mechanism and motor.
Installation
"¢ In reverse order.
Lower Tailgate Panel
Removing the rear door panel
"¢ Remove 2 screws on each side
"¢ Begin by detaching the panel at the window (eight covered clips in total).
NOTE: When removing, note the position of the screws (the screws are two different lengths).
Installing the rear door panel
Install:
In reverse order.
NOTE: Ensure that the guide pins are correctly position before pushing the panel into place.
NOTE: Ensure that the clips click when they are pressed into place.
Oct 31, 2009 at 1:35 PM
