we are trying to replace the motor mounts, having trouble getting the bottom front one out. How do you remove the old one?
Jul 11, 2010 at 6:57 PM
JIS001
CERTIFIED EXPERT
It would help if you had a hoiste? To replace it you need to remove the upper beam out of the way. Remove the engine mount bolts. Remove the bolts for the lower torque rod. Using a jack under the transmission jack up the engine. Remove the engine mount and install the new one.
