Turn Signal V70 wagon 2001 4WD, 60,000 miles
2001 VOLVO V70
BILL FURR
On right turn only blinker will go at a faster than normal rate, and will receive message of bad bulb. I have replaced all bulbs and problems still occurs. This is an intermit problem.
I have checked bulbs, and also checked the grounding to each socket.
When the four way flasher is used all works ok. Could this be a flasher problem and if so where would the flasher be loacted?
Sep 19, 2007 at 11:07 AM
BMRFIXIT
  • 19,053 POSTS
[quote:97edd52037="Bill Furr"]On right turn only blinker will go at a faster than normal rate, and will receive message of bad bulb. I have replaced all bulbs and problems still occurs. This is an intermit problem.[/quote:97edd52037]
make sure you used the correct bulb and installed it the correct way
check the Socket and the ground wire
Sep 19, 2007 at 7:55 PM
