2001 Volvo V70 Grinding noise in my rear wheel
2001 VOLVO V70
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
CPASCAL
When I brake slowly I am hearing a terrible grinding sound coming from my rear right rear wheel area. When I move forward, I also am hearing the grinding sound, but it goes away as I gain speed. Also, some times when I brake I don't hear it all. My dealer said they checked the rear brakes about 2 weeks ago and they were okay. My brakes seem to be working fine btw.
Thanks for help
Connie
May 29, 2010 at 4:49 PM
JIS001
  • 3,412 POSTS
Do you have Volvo brake pads installed or aftermarket brake pads? Usually low quality brake pads will make the grinding noise while braking. Not to say that Volvo pads cant do the same thing but it is very rare. Some brake noise is normal and differences in loading, type of driving, or driving style can make a difference in brake wear. Depending on weather conditions, driving patterns and the local environment, brake noise may become more or less apparent. Verify all metal-to-metal contact areas between pads, pad guides, caliper and knuckles are clean and lubricated with a thin layer of high temperature silicone grease. Brake noise is caused by a "slip-stick" vibration of brake components. While intermittent brake noise may be normal, performing 3 to 4 aggressive stops may temporarily reduce or eliminate most brake noises. If you still have noise then the brake pads will need to be replaced.
May 30, 2010 at 10:49 PM
