2000 Volvo V70 Will not stay running
2000 VOLVO V70
207,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAMMY BC
I have ask many people. I have a issue that my car keeps cutting off when you come to a stop or when you go from park to a gear. Now it is shutting off as you pull into a parking place . I Really cant afford to put it in the shop right now PLEASE help ME
Jul 18, 2010 at 11:14 AM
JIS001
  • 3,412 POSTS
At the very minimun you should remove the throttle body and clean it out. After remove the fuse out for the ECM in the engine compartment andleave it out for a couple of minutes. Reinstall te fuse and road test for a bit. Also with the amount of miles you have, your PCV system could be plugged up as well but you would need to have it checked out. If the PCV is plugged then that will also cause some issues with it stalling.
Jul 18, 2010 at 8:42 PM
