2000 Volvo V70 drive shaft removel
2000 VOLVO V70
90,000 MILES • 4 CYL • FWD • MANUAL
GRUFFY
how do i remove the drive shafts from the car i have taken off the wish bone and raised the s spings to do this but have now got stuck and cant get the inner end of the shaft out of the engine ?
Aug 20, 2009 at 1:46 PM
DOCFIXIT
  • 18,828 POSTS
Here's the trick shaft has lock ring holding it in. Get a BIG screwdriver or better prybar. Place between trans housing and Cv joint taking care of seal then pry out . Give it a good pop
Aug 20, 2009 at 2:12 PM
GRUFFY
thanks that helps a lot is it the same for both sides as the other side looks like it is going into another shaft under the engine into the gear box.
Aug 21, 2009 at 5:55 AM
DOCFIXIT
  • 18,828 POSTS
On that side need to take bearing cap off pull on inner shaft see figure
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_89.jpg
Aug 21, 2009 at 8:30 AM
GRUFFY
thanks for the diagrame
am i right in thinking the non gear box side is a long shaft or would it come apart just outside the bearing on that shaft
Aug 22, 2009 at 6:56 AM
DOCFIXIT
  • 18,828 POSTS
No it will come out of trans
Aug 22, 2009 at 10:38 AM
