1999 Volvo V70 head gasket
1999 VOLVO V70
RETIREDMEC
Engine Cooling problem
1999 Volvo V70 4 cyl All Wheel Drive Automatic
what are my options milk in oil?
Feb 14, 2010 at 10:24 PM
JIS001
  • 3,412 POSTS
If you have no driveability issues then I would suspect the oil cooler has an internal coolant leak. Oil cooler is attached on the oil pan. If vehicle runs like crap with smoke coming out the tail pipe then you have a leaking headgasket.
Feb 17, 2010 at 10:34 PM
RETIREDMEC
appreciate response, this car rus like dream,1st
suspected head gasket,just had top rebuilt couple
months ago,mec shop also said oil cooler,,i did,nt
beleive em,,,looks like you nailed it, is this repair
extensive/expensive?
Feb 18, 2010 at 4:32 PM
JIS001
  • 3,412 POSTS
Depends on how you want the repar. If you just replace oil cooler then it wont be expensive but you will also need to flush out the cooling system to get rid of the oil and would also recommend you replace all your rubber hoses since oil and rubber do not go well with each other. So it can start adding up. You may also want to replace the expansion tank as well.
Feb 18, 2010 at 8:51 PM
