1999 Volvo V70
1999 VOLVO V70
PONJA
Engine Mechanical problem
1999 Volvo V70 Four Wheel Drive Automatic 140000 miles
The car has a check engine light on and I was told that the code was 1550. My mechanic didn't know what it was at the moment and told me to come back. Can you help?
Thank You
Nov 26, 2009 at 11:27 PM
KHLOW2008
  • 41,814 POSTS
Hi ponja,
He are the description of the problem.
P1550 , P1551, P1633/ECM -510F: VEHICLE SPEED SIGNAL
Fault Conditions
ECM- 510F is stored when an error message is sent to ECM if a fault in vehicle speed signal has been detected in ABS control module.
(DTC ECM- 510F (no signal) is stored if there is no communication between the ABS/brake control module (BCM) and the ECM or if the communication is distorted. An error message is sent to the ECM and DTC ECM- 510F (signal too high/too low) is stored in the engine control module (ECM). DTCs for the Vehicle Speed Sensor (VSS) signal are stored in the ABS/brake control module (BCM).
No substitute value is used. Misfire diagnostics is switched off while ECM- 510F is set.
MIL is illuminated while ECM- 510F is set.
Possible Causes (Signal High Or Signal Low)
Vehicle speed sensor signal from ABS control module is faulty or missing. Defective vehicle speed signal to the ABS /brake control module (BCM). A DTC is stored in the ABS /brake control module (BCM).
Possible Causes (Signal Missing)
• Contact resistance in the Controller area network (CAN) terminals
• Open circuit in one or both CAN cables
• One or both signal cables short-circuited to ground, voltage or each other
• Defective ABS /brake control module (BCM)
• Defective engine control module (ECM)
Diagnostic Procedure
For wheel speed (vehicle speed) sensor diagnosis, see appropriate ANTI-LOCK, WITHOUT TRACTION CONTROL article in BRAKES.
© 2008 Mitchell Repair Information Co., LLC.
Nov 27, 2009 at 2:55 AM
PONJA
Thank you very much.
Nov 28, 2009 at 10:31 PM
KHLOW2008
  • 41,814 POSTS
You are welcomed and glad to be of help.
Nov 29, 2009 at 2:29 AM
PONJA
It's me again. I did not have much luck with the repair shop:(
Until I find someone who can take care of this problem can you please let me know what are the possible repair option. Thank you.
Dec 6, 2009 at 12:12 AM
KHLOW2008
  • 41,814 POSTS
I checked through the database and some other shops had encountered the problem which seems to have occurred previous.
The problem stems from a broken soldered joint in the ABS/TRAC module in the wheel speeed sensor partition of the board.
Remans are available at a reasonable charge.
Dec 6, 2009 at 4:34 AM
