1998 Volvo V70 Turbo
1998 VOLVO V70
PATTHERAT
Engine Mechanical problem
1998 Volvo V70 All Wheel Drive
Bought a used 1998 volvo v70xc and am trying to replace the turbo. Am experienced in automotive but not with volvo. Need instructions to remove and replace turbo.
Aug 11, 2010 at 5:59 PM
JIS001
  • 3,412 POSTS
You need to remove the fresh air tube for the air cleaner, the feed pipe for the turbo, the 2 17mm banjo bolts for the coolant and the 17mm banjo bolt for the oil, the 3 13mm nuts for the cat to turbo and 4 13mm nuts attaching the turbo to the exhaust manifold.
Aug 29, 2010 at 2:09 AM
