Electrical problem
1998 Volvo V70 6 cyl Two Wheel Drive Automatic
Had trouble removing the ignition key, but that is fixed now (gear shift release button was sticking).
Now the problem is the key will turn to first position (steering wheel unlocks), but will not turn to the other three positions (car will not start).
Have tried WD-40 w/out luck. We have had a lot of rain and car has gone through puddles for last week.
Wondering if the gearshift cable needs adjustment, or if the ignition lock cylinder needs adjustment or replacement. (is this the same as ignition switch?).
Thanks
Thanks
May 23, 2009 at 11:03 AM
