1998 Volvo V70 Front Passenger Door
1998 VOLVO V70
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
CMCDANIEL
The door cannot be opened using the inside
latch. The door will open from the outside,
but if you pull on the door handle inside the car
it will not open the door. The handle only pulls about half way out on the inside as well, you can't pull the inside door handle completely out.
Jul 22, 2008 at 12:27 PM
DOCFIXIT
  • 18,828 POSTS
Need to pull door panel off and see what is up with the rod. What is causing it to fail to opeh latch.
Jul 22, 2008 at 12:42 PM
