2004 Volvo V40 P0171 Code LTFT 17.2
2004 VOLVO V40
98,000 MILES • 4 CYL • FWD • AUTOMATIC
STEPHENKERI
So this Volvo seems to act up with a hesitation after the fuel tank is filled. After accelerating it is fine and never comes back until next tank fill.
(PDF of freeze frame and recorded data can be supplied in PDF.)
Engine light on, Code P0171
Scanner displays at
idle the MAF reading of 0.31 Lbs/Min
=2.34 g/s.
At 2000rpm MAF reads 0.87 lbs/min=6.57 g/s
Did notice that at idle the TPS reads 12%? But that would actually richen it up I would think?
Temp sensor and all sensor data looks good, O2 Sensor switches normally. Rapidly at 2000rpm, less rapidly at idle but still switches well at idle. Only thing i did notice on o2 was after throttle blip it hesitates for a second or so before dropping and switching again.
Checked thoroughly for vacuum leaks, none found, tested engine vacuum, nice steady 18 at idle, looks good when run through rpm.
Fuel pressure is well within specs,
Replaced spark plugs and fuel filter for good measure.
It is a turbo charged engine and am concerned I may be overlooking something.
Please any help is good help.
Oct 27, 2010 at 6:06 PM
P0171
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Oct 28, 2010 at 4:39 AM
JIS001
  • 3,412 POSTS
Do you have a howling noise with the check engine light on? If you do, then you have an internal vacuum leak in the oil trap box. You may still be covered by an extended emissions warranty of 10 years/150k miles to get it replaced at no charge. If that is ok, make sure oil cap is properly secured and oil dipstick is properly secured as well. If left loose, this will cause fuel trim problems as well. Inspect for any leaks and pay close attention to the pcv hose that is on the oil trap. The oil trap is the oil filter housing. Remove air snorkel from air box like you would to access oil filter. You will see a hose that attaches to the box and goes up to the cam cover. That hose gets brittle and breaks causing an intake leak. They also tear in between the plastic intake and cam cover but you would need to remove the plastic intake off to inspect. If that hose is damaged, replace it and unplugg the engine control module connectors on the side of the air box to reset fuel trim adaptations. If all that is good, you have a dirty throttle body and you will need to remove it to clean it. Once you clean it, unplug the ecm connectors to reset fuel trim adaptations for this repair as well. After you clean it, take it in to Volvo to see if there is an available software update for the ECM. If there is one, have it done. This will recalibrate the mass air flow sensor and reduce the number of adaptations it sees so it will not be so sensitive and trigger the light from coming on. Also does not hurt to ask if the software will be covered by the extended EMS software warranty which is also 10 years/150k miles but that is not always the case? Just let them know you did some repairs and you wanted to have the ECM software updated. Good luck and let me know what you find.
Oct 29, 2010 at 1:42 AM
