1998 Volvo S90 oil leak
1998 VOLVO S90
JULIANANDRES707
1998 Volvo S90 Automatic 132200 miles
Hi..
I can see smoke coming out of the dip stick area, and after driving, oil is on the engine in this area.
I put a cover in the dip stick hole and 10 seconds after I heard air leaking from another part of the engine, after I put a hose over the dipstick hole that comes out the bottom of the engine and now after I drive the engine stays clean, so oil is leaking out of the dipstick.
who can i fix the leak?
Feb 21, 2010 at 4:29 PM
JULIANCIFUENTES
Change the pcv valve. Is cheap and easy.
You need to check the engine seals.
Oct 6, 2012 at 11:26 PM
