1998 Volvo S90 brake noise
1998 VOLVO S90
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRIAN OVER
my volvo's front brakes make a creaking or snapping noise most of the time when i depress the brake pedal. the noise comes from both sides. I had it serviced and inspected at a volvo dealership. They could not duplicate the problem. the brakes and rotors are relatively new. it stops fine although the noise is annoying. I bled all the brake lines over the summer. this had no effect. thank you in advance
Jan 17, 2010 at 5:18 PM
DOCFIXIT
  • 18,828 POSTS
Could be suspension components like control arm bushings, ball joint,struts and mounts. hear any noise going over bumps? do it in REV when braking?
Jan 21, 2010 at 11:39 AM
