hi, can any machenic have a diagram of the hood area, it will not unlock after i pull the handle inside on the driver side, thanks tom
Jul 11, 2010 at 3:51 AM
INTERNETMECHANIC
CERTIFIED EXPERT
Sorry, I didn't see a hood diagram. With mechanical release mechanism, sometimes it helps to have a helper pop the hood with palm of the hand, in area of release mechanism, at the same time you pull the inside release mechanism. If that doesn't work maybe you can pull the grill and reach the release mechanism. When you get it up, lube the mechanism. Thanks for the donation.
