2002 Volvo S80 possible idle problems
2002 VOLVO S80
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
TKILFORD
I have a check engine light. I put a computer on it and the code was P0507. The definition was the Idle Air Control circuit or idle speed higher/lower then expected. Explanation was that the ECM has detected that the IAC counts are higher or lower then expected. The engine speed is not it's expected range. The four probable causes were vacuum leak, dirty throttle body, IAC motor defective, or poor electrical connection to the IAC valve. Is there anything you can tell me about this. How much does it generally cost to fix? Is this a common problem for this year and make vehicle? etc. etc. Thank you.
Feb 21, 2009 at 11:21 AM
DOCFIXIT
  • 18,828 POSTS
Don't know if it is common to your car but all cars that have that code first to do is clean throttle body and plate. Remove IAC clean. Erase code and drive . if no light your good.
Feb 21, 2009 at 12:13 PM
JIS001
  • 3,412 POSTS
Take your vehicle to your local
VOLVO dealership for proper diagnosing. Your Electronic Throttle Module has a 10 year 200k mile warranty on it and if it turns out to be the problem they will replace at no charge. Do not clear the codes so that they can scan it. Costof ETM if you were to buy it is about $1000 bucks plus labor and software to reload so dont tamper with it or you could void out the extended warranty.
Mar 29, 2009 at 4:24 PM
