2002 Volvo S80 Key won't work
2002 VOLVO S80
90,000 MILES • 6 CYL • FWD • AUTOMATIC
VANVELB
It started 6 months ago and is slowly getting worse. The key (both keys) will not unlock steering wheel and allow you to start the car.10
Feb 15, 2010 at 11:42 AM
2CARPRO JACK
  • 11,533 POSTS
If both keys are doing it, the lock cylinder may be wearing out, causing the keys not to work.You could try a lock lube (Dry graphite), sometimes the tumblers get sticky and just need a little lube to help them out, but use only a lube specifically for locks, wet lubes will cause gumming and could make it worse
Feb 15, 2010 at 3:26 PM
