2000 Volvo S80 Fuel Pump Inertia Shut-off Switch
2000 VOLVO S80
155,600 MILES • 6 CYL • FWD • AUTOMATIC
NWFLYMOM
  • 4 POSTS
Where is the fuel pump inertia shut-off switch located on this vehicle?
May 23, 2009 at 3:19 PM
I've checked in Mit1 ondemand5 there's no listing having one for a fuel cut off inertia switch.
May 23, 2009 at 6:13 PM
NWFLYMOM
  • 4 POSTS
Thanks for your reply. Son hit a curb and flattened right front tire, so I figured there was a fuel cut-off switch since it would not crank after cut off. I cannot even find the repair manual locally! Anyway, thanks for trying...Single mother of 3 and money is tight, but need car to work....Take care...nwflymom
May 23, 2009 at 6:38 PM
When you turn key to run do you hear the fuel pump come on in the fuel tank?? If not could be a fuse or fuel pump relay
May 23, 2009 at 6:41 PM
NWFLYMOM
  • 4 POSTS
Checked the fuses. Don't know where the fuel pump relay is. Parts stores told me they cannot even ORDER the repair manual for this car. I am totally frustrated! Thanks for trying. [email protected]
May 23, 2009 at 7:45 PM
NWFLYMOM
  • 4 POSTS
I do think I hear the fuel pump come on, too.
May 23, 2009 at 8:14 PM
Check fuse no.33 15amp in the passenger compartment fuse box left end of dash and the fuel pump relay is the engine comaprtment relay box.
https://www.2carpros.com/forum/automotive_pictures/12900_fp_volvo_1.jpg
May 23, 2009 at 11:12 PM
