2000 Volvo S80 AC blows warm moist air when outside temp ab
2000 VOLVO S80
188,000 MILES • 6 CYL • 2WD • AUTOMATIC
1984TIGER
My S80's AC seems to work fine until it gets above 85 outside. Then it will work for 2-3 minutes then blows warm moist air. Turning it off for 15 minutes will get you another2-3 minutes of cold air. Volvo tech has checked for leaks but none found, figures it is time to change the compressor.
Jul 10, 2009 at 1:23 PM
JIS001
  • 3,412 POSTS
Your compressor clutch could be worn out already. Have the gap measured. should be between .3mm and .5mm. If it is beyonde that then your compressor clutch is worn and it is replaceable. My
S-80 is starting to do the same thing because of the worn clutch but have being a little busy to get around too it LOL. I dont mind driving with the windows and sunroof open. Will wait till my wife starts to complain about it before I get around to replacing mine.
Jul 11, 2009 at 7:01 PM
