1999 Volvo S80 water pump
1999 VOLVO S80
KROSSANESE
  • 6 POSTS
Engine Mechanical problem
1999 Volvo S80 6 cyl Front Wheel Drive Automatic
I would like to know if there is a trick to removing the water pump from this vehicle it seems as if everything is loose but i cant get the pump out any ideas
Nov 11, 2010 at 9:26 AM
JIS001
  • 3,412 POSTS
Remove the 2 front engine pad bolts. Remove the upper bar for the upper torque mount. Get a floor jack and a piece of wood and jack up the engine. That should give you some more clearance to get the pump out. Good luck and hope this helps.
Nov 13, 2010 at 4:55 AM
