2000 Volvo S70 turn signal relay location
2000 VOLVO S70
POPP36
  • 4 POSTS
Electrical problem
2000 Volvo S70 4 cyl All Wheel Drive Automatic
I need to know where the turn signal relay is located. I have the part just need to know where to put it!
Mar 7, 2010 at 2:52 PM
JIS001
  • 3,412 POSTS
What kind of problem are ou having? If there is no power going through the fuses then under the hood in the relay box it will be relay 106. If the turn signals are not flashing then you need to replace the hazard switch since that is also the flasher.
Mar 8, 2010 at 1:19 AM
