2000 Volvo S70 Coolant keeps getting low
2000 VOLVO S70
32,600 MILES • 4 CYL • 4WD • AUTOMATIC
DEMIVENTERS
At first, the coolant keep getting low, then I was told the radiator needed to be placed; it was fine for a while, then the window would fog so I was told I need a heater core which was replaced; last, I had the transmission replaced and now the coolant light is not coming on and the coolant keeps getting low; I have to fill the coolant at least every week, please help, thank you
Feb 8, 2010 at 10:41 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to get a cooling system pressure test done to check for any external leaks and a Co test done to check for any exhaust gasses in the cooing system, this is a sure sign of a head gasket problem, start here.
Mark (mhpautos)
Feb 9, 2010 at 4:06 AM
