My Volvo is really a 5 cyclinder.
A couple of questions.
1. When the outside temperature is above 80 degrees and after I've operated the car about 45 minutes, the ABS light will sometimes come on and cruise control will kick off. If I try to reset the cruise control, it will not ingage. The ABS is on from this point on. Only after stopping the car and it being off for at 30 minutes wiill I be able to use cruise control. When I get back in and start the car after the time off, the ABS light is still on. It goes off the first time I use the brakes and I'm ethen able to use cruise control until the sequence occurs all over again with the right conditions???????
2. Where is the intake value (low pressure side) of the air conditioning system located?
Apr 30, 2009 at 8:08 AM
