2007 Volvo S60 Tire Rotation
2007 VOLVO S60
23,000 MILES • 6 CYL • AWD • AUTOMATIC
LILDOOL21
I rotated my tires on Saturday (front to back, back to front), keeping them on the same side of the vehicle, as the owners manual states. However, I have been hearing a sound from the tires (screeching almost like I'm peeling out), whenever I go around turns or I'm above 40mph. All I did was rotate the tires, not sure why I would now be hearing this noise. Any thoughts would be greatly appreciated.
Thanks,
Bill
Jun 29, 2010 at 8:50 AM
JIS001
  • 3,412 POSTS
The tires are not easy to mount back since there is no wheel studs to help guide it back on. What I believe may have happened is that one or more of the tires may have slipped on you causing the backing plates to bend. Normally you should hear it right away while driving straight but I have had that problem with it only making noise on turns only. So what you need to do is bend back the backing plates away from the rotors and let me know if that helps. Good luck to you.
Jul 1, 2010 at 1:58 AM
