vibration while braking?
2004 VOLVO S60
52,195 MILES • 4 CYL • FWD • AUTOMATIC
ROBRON
Good day. This is a follow-up question regarding the vibration while braking?Volvo workshop recommended for complete new tires and rims and so i did. After doing so, the problem still persist. Now they are recommending the collapsed front suspensions to be changed as the potential source of the vibration problem. I am not satisfied with their diagnosis, said it could be the engine supports or the engine itself which is being opposed by volvo workshop. What do you think shall i do? thank you very much.
Nov 1, 2009 at 2:52 AM
SEVAG P
  • 405 POSTS
hello,
Vibration while braking sounds like front rotors has excessive runout must be replaced with front pads.
check our link below how to replace front brake discs and pads
Check the diagrams below how to replace the pads and discs with the calibration and the rotor lateral run out test.
hope these helps.
thank you.
Feb 19, 2021 at 7:33 PM
