where is the oil filter location and how do you change it.
Oct 1, 2009 at 9:34 AM
JIS001
CERTIFIED EXPERT
The oil filter is located on the oil pan. It is inside the black canister on the pan. You need a secial tool that will fit on the housing to remove it. If you try using pliers you will break the housing since it is made of plastic.
