2001 Volvo S60 OIL LEAK
2001 VOLVO S60
119,000 MILES • 4 CYL • FWD • AUTOMATIC
FHYCSS
THERE IS AN OIL LEAK COMING FROM THE TOP OF MY ENGINE BEHIND THE TIMING BELT...WHERE IS THE OIL COMING FROM?
Nov 27, 2009 at 10:38 AM
KHLOW2008
  • 41,814 POSTS
Hi fhycss,
The area that can leak behind the timing belt are the valve cover gasket and/or camshaft oil seals.
Nov 27, 2009 at 12:50 PM
FHYCSS
Thank you very much for answering my question...It is appreciated.
Nov 28, 2009 at 6:54 AM
KHLOW2008
  • 41,814 POSTS
You are welcomed.
Oil leaks can contaminate the timing belt causing premature failing so it should be rectified asap.
Nov 28, 2009 at 7:06 AM
