I have an oil leak from the upper part of my engine. I have removed the timing belt cover and some oil is present as it is being slung around by the cam shaft pulleys and timing belt. I have been planning to change the timing belt but the oil leak should be fixed first, right? I have ordered a timing belt kit but I do not think I should contaminate the new belt with engine oil.
Is there a prime suspect (gasket or seal) for the source of this oil leak? Is there an immediate danger that oil contamination may cause an issue with the timing belt? I am worried the oil could could cause a timing belt slip? Thanks for your help.
Dec 20, 2009 at 10:19 AM
