Labor will be around 5 hours so multiply that by the shops hourly rate. Parts varies but you will need the manifold gasket, turbo return seals, 6 copper washers, turbo gasket, maybe cat to turbo gasket if applicable, and a gallon of coolant. They will also need to check the manifold for warpage and cracks. If it is badly warped or cracked then you will need that also.
Apr 9, 2010 at 4:10 PM
