2002 Volvo S40 Alternator charging
2002 VOLVO S40
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
ZSELECPE
How long does a car need to be run (or engine to be idling) to re-charge a battery which has gone mostly dead but has been jumped successfully? Thank You, Pete z.
Aug 25, 2009 at 9:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
With the car idling you will only get what is called a surface charge, this is not enough to normally get the car going if you turn it off, at least take it for a long drive so the alternator can charge at peak volts, remember that the alternator is not designed to fully deep cycle charge a battery from a fully flat stat, it is designed to keep the battery topped up while demand is placed on it from all the systems that it feeds.
mark (mhpautos)
Aug 25, 2009 at 9:13 PM
