2001 Volvo S40 Replaced Pass CV Shaft. Have slight all-time
2001 VOLVO S40
110,000 MILES • 4 CYL • FWD • AUTOMATIC
JRLOGAN67
It seems to only stop when I turn the steering wheel to the right. The pass side was replaced. The noice occurs even when the car is crusing and not accelerating.
May 30, 2010 at 12:49 PM
KHLOW2008
  • 41,814 POSTS
Hi jrlogan67,
Thank you for the donation.
If it is grinding noise that you are encountering, check the front backing plates to see if if they are too close to the rotors.
May 30, 2010 at 2:23 PM
JIS001
  • 3,412 POSTS
If you have a rumbling noise then your wheel bearing is bad. when you turn right the noise goes away because you are taking weight off that side during the turn.
May 30, 2010 at 10:26 PM
