My car was leaking oil in the front. The autoshop who evaluated the fluid leak indicated that they found leakage from the upper and lower oil pan gaskets and both output shaft seals. Leakage due to age/heat. They recommended that I remove and replace the following:
Oil pan &/or gasket (1)
Oil pump seal -front (2)
Output shaft seal - left (1)
Output shaft seal -right (1)
They told me the work would take the whole day and labor approximately $2000. I've done some preliminary research and it looks like the work shouldn't take the whole day. I'm wondering also why the oil pump seal needs to be replaced if there's no leakage from there. I'd appreciate your thoughts on the auto shop's recommendation/time needed.
Thanks
Thanks
Jun 27, 2010 at 11:17 PM
