Not a fuse or bulb problem as far as I can tell. I am on vacation in Orange Beach, AL and need to try to fix this myself. I fiddled with the brake light switch a little, and the brake lights are kind of acting like they are shorting out. Sometimes they work and sometimes they don't. If I fiddle with the switch I can get the lights to flicker, etc., but can't really tell if the switch is sticking or if it is a bigger problem. I am thinking of buying a brake light switch and installing it myself to see if that works. I know enough to get to the switch but I need to know how to remove the old one and put the new one in. Also would like to know if this is a good idea, or whether I should just have someone look at it. I don't have an ohmeter or any tools really and I am not skilled enough to really isolate the electrical problem outside of hoping it is the switch and knowing it is not a bad bulb or fuse. Can you help??!!
Mar 25, 2010 at 10:00 PM
