2000 Volvo S40 vibration
2000 VOLVO S40
102,000 MILES • 4 CYL • 2WD • AUTOMATIC
HOPGOOD30
My name is Justin. I own a 2000 Volvo S40 1.9L turbo, it has about 102,000 miles on it. Sometime last month a strong vibration started to occur. Both CEL and SEL came on. While at lights the vibration is strong (during idle) but when I press on the gas the vibrations decreases. I have hard starts from time to time but not often. My steering wheel shakes from the vibration. I have already had a tune-up about 2,000 miles ago. I went to a shop and talk with a mechanic; he said it sounds like a fuel injector. I was wondering from what i have said could you give me some possibilities, before I go out and spend a bunch of money on things that I should have to replace. And I noticed that my engine mounts (passenger side) bolts (two of three) have sheared off due to the vibrations. If you have any at all suggestions please email me at [email protected]
Sep 15, 2008 at 12:08 PM
2CARPRO JACK
  • 11,533 POSTS
If the engine runs smoother at higher rpm's then it could very well be a bad injector. Use a meter to measure the resistance across all of theinjectors to see if one is different than the others, that will be the bad one. Have a compression test done first to be sure the engine is ok before spending money on other things
Sep 16, 2008 at 7:43 AM
