2000 Volvo S40 Immobilizer
2000 VOLVO S40
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
ADCYCLE
My key is stuck in the ignition and it will not start at all. The battery is fully charged. The battery on the keyfob is new. What can i do to fix it???
Jan 27, 2010 at 11:22 PM
JIS001
  • 3,412 POSTS
If you put your car in nuetral then most likely it will start. if it does start and not in park with the key being stuck then check the gear selector button. If it does not depress out then it is if like your car is not in park causing the key to not come out. This could also be why your car will not start especially if it still thinks it is in reverse. If the button in the gear selector is stuck, try to pry it back out. This should release the key and should let you start the car up. Let me know what happens.
Jan 30, 2010 at 3:28 PM
