Hi, I have two problems that may be connected. They happened when I brought the car home from the shop after having been towed.
1. The key will not come out of the ignition;
2. When I got home from the shop and turned off the ignition, I tried to get the key out and it would not come out but the rear Passenger Roll Bars popped up and are now in a deployed state.
-- I have read on-line that fire departments can have the volvo dealer demonstrate the roll bar deployment so that they can be prepared when responding to an accident. So, I am assuming that it is an easy fix to put the roll bars down. But, the dealer apparently never has seen the problem and tells me that the two roll bar units must be replaced.
-- Do you have any idea why these things happened?
-- How extensive the fixes might be?
-- Who I should take it to be fixed?
-- Whether there is a repair manual available to assist?
Thank you very much!
Feb 7, 2010 at 4:13 PM
