1999 Volvo C70 Engine revving while in Park 'idling' or in
1999 VOLVO C70
WHOSYODADDYOOORAH
Engine Mechanical problem
1999 Volvo C70 Front Wheel Drive Automatic 124000 miles
My engine is a 5-Cylinder Turbo charged. When operating my car in 'Park' or "nuetral' my engine revves (from an idle RPM to a higher RPM) in an oscillating fashion. This does not happen when the car is in 'Drive' or 'Reverse'. Any idea what's causing this?
Mar 9, 2010 at 8:50 AM
KHLOW2008
  • 41,814 POSTS
Hi Whosyodaddyooorah,
Thank you for the donation.
The idling speed is higher than expected causing the surging.
• Check coolant temperature sensor and connection.
• Check air temperature sensor and mass airflow meter.
• Check coolant temperature sensor.
• Ensure spark plugs are not fouled.
• Check ignition and sensor wires for proper connection.
• Check ignition and coil circuit.
• Check intake system.
• Check coolant level.
Mar 9, 2010 at 12:12 PM
