1997 Volvo 960 how to remove the starter exactly
1997 VOLVO 960
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUGGS BUNNY
i want to know how to remove my starter
Aug 18, 2010 at 8:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable at the battery. Disconnect the leads from the starter motor. Remove the starter motor retaining bolts. Remove the starter motor from the vehicle. To install: Position the starter motor to the flywheel housing. Apply locking compound to the bolt threads and install the retaining bolts finger-tight. Tighten the bolts to approximately 25 ft. lbs. (34 Nm). Connect the starter motor leads and the negative battery cable.
https://www.2carpros.com/forum/automotive_pictures/261618_1_190.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_2_121.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_3_54.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_4_23.jpg
Aug 18, 2010 at 8:51 PM
