1995 Volvo 960 code 113 and 121
1995 VOLVO 960
167,000 MILES • 6 CYL • 2WD • AUTOMATIC
CASCH46
Mechanic said there was a short in the wires that go from the injectors and run the whole car so I would need the whole engine wiring harness which cost $2000.00 and the labor $1000.00 because he had to remove the manifold The car when running would choke out and shake and stop i would wait a few minutes and it would start up and then the same thing if i only go a few minutes from the house no problem
Nov 13, 2009 at 10:53 PM
KHLOW2008
  • 41,814 POSTS
Hi casch46,
Thank you for the donation.
Code 113 is for the fuel injectors.
Code 121 is for the MAF.
I woud suggest getting a second opinion. Unless the wire harness is badly damaged, there is no necessity to replace the complete harness. I would suspect the MAF to be the main cause of the problerm and it could be only due to loose or contaminated wire connectors.
Nov 14, 2009 at 2:43 PM
