1993 Volvo 940 High Pitched Grinding Noise on the Engine
1993 VOLVO 940
142,000 MILES • 4 CYL • 4WD • AUTOMATIC
RJJOHN43
My engine makes a loud high pitched noise that changes with the RPM's. It almost sounds like a metal on metal grind. Could it be the Harmonic Balancer?
May 30, 2008 at 10:44 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Remove all drive belts and run, if noise is gone it will be in an accessory drive item, if still there, i think you will have to get a mechanic to listen to it as you will need to hear it first hand to help locate it.
Mark (mhpautos)
May 31, 2008 at 1:58 AM
RJJOHN43
I actually did take it to a mechanic and he recommended a new timing belt and tensioner.
May 31, 2008 at 6:08 PM
