codes check engine light on?
1993 VOLVO 940
184 MILES • 6 CYL • 2WD • AUTOMATIC
JIM234
  • 4 POSTS
My check engine light came on yesterday. When I push the accelerator it chokes. I leave it off for a while and it runs and then happens again. Check engine light still on. I read the codes and get
1-2-1
which is
MAF sensor signal absent or faulty LH 2.4 or 3.1
what is this code?
Thank You
Jim
Jun 14, 2009 at 11:41 AM
RACEFAN966
  • 5,029 POSTS
Ok here is the diagnostic procedures to test the mass air flow unit and wiring to determine if you should replace the sensor or not. You will need to save pic and then enlarge so you can read it and test it. Let me know how it goes.
https://www.2carpros.com/articles/volvo-code-definitions-and-code-retrieval-procedure-1983-to-1993
Jun 15, 2009 at 1:43 PM
